Date/Time: Sun, 08 Sep 2024 00:32:10 +0000
Restrict certain contracts
View Count: 335
[2024-06-25 18:23:05] |
karohm - Posts: 200 |
Is it possible to restrict mini contracts any how? I just want to be able to trade micro contracts |
[2024-06-25 18:58:32] |
There is nothing in the system that prevents you from trading any particular product. The best option is to make sure that any charts of the Mini contracts are not set to allow trading. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-25 19:04:06] |
I need it to be disabled somehow. I cant help but execute trades in mini contracts which i dont want to. Execute As in not by mistake but deliberately. |
[2024-06-25 20:57:57] |
There is nothing within Sierra Chart that can do this. But you should be able to be limited at the broker level. Check with your broker to see if they can limit the symbols that you have available for trading.
[2024-06-26 05:20:03] |
I have asked IBKR about it once in the past they said its not possible, I will ask them again. But are you aware of any brokers that could do it ? Thanks |
[2024-06-28 17:19:09] |
Sierra_Chart Engineering - Posts: 16292 |
Yes, this can be done through Teton order routing: Sierra Chart Teton Futures Order Routing You can find a list of brokers supporting that service on that page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-28 17:19:58
[2024-07-02 15:03:03] |
Thanks for that. To be more specific : would i be able to do this assuming I have NQ restricted from the broker : like have a chart with NQ contract loaded and in settings i would put MNQ as trade and quote symbol, so would the orders go through for MNQ ? |
[2024-07-02 16:23:01] |
In this situation the order is for MNQ and that is what is sent to the exchange. There is nothing related to NQ being sent through, so this would not be blocked. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-02 16:26:54] |
Thanks, Although I was certain, just wanted to make sure. Do you have any recommendation as to which broker i should go with from the listed teton supported brokers? I am thinking to go with Edgeclear |
[2024-07-02 16:46:31] |
We do not have any specific recommendation between the brokers that support our Teton Order Routing Service. You are welcome to open another post asking the other users for their opinions. If you do, set the post as "User Discussion" - there is a pulldown menu to select this with a "Set" button to the left (select "User Discussion" then select the "Set" button).
[2024-07-02 16:53:35] |
Okay. Just this last thing : with a funded stage clear (dorman as clearing firm) , ill be able to keep my sc Account as non professional right ? |
[2024-07-02 17:26:11] |
Yes as long as you are considered nonprofessional by the exchange.
[2024-07-02 19:30:55] |
Stage 5 Trading - Posts: 155 |
Hi Trader, Stage 5 Trading is a brokerage firm that works closely with Sierra Chart to provide traders with the high level support to help them utilize Sierra Chart to it's full capabilities. With that being said, Stage 5 has an in-house platform team that can setup the contract limit restrictions directly on your account. You can open an account for as little as $100 and you will receive $0.20 per side commissions on the micros and $0.45 commissions on non micros plus exchange and regulatory fees. If you have questions or would like to speak to an assigned personal broker for details, please call us at 1-312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/ If you are ready to move to the Teton Order Routing solution right away, we invite you to complete an application by clicking the blue button at the top of the https://stage5trading.com/ page that says Introducing Sierra Chart Teton Order Routing - Click Here to Open an account Thank you, Anthony Giacomin Stage 5 Trading Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results. |
[2024-07-08 13:55:51] |
Hi, I just got setup with TETON with Dorman I just got to know MIT non client side orders are not available with TETON, idk why. Can i expect it to be available anytime? Another thing, I am placing stop market orders but on the chart its showing as stop limit orders and the functioning is of stop market order. Why is it showing me stop limit on the chart ? Thanks |
[2024-07-08 16:15:04] |
We do not know if/when we would change this. Another thing, I am placing stop market orders but on the chart its showing as stop limit orders and the functioning is of stop market order.
Why is it showing me stop limit on the chart ? Refer to the following: Order Types: Stop Orders on the CME For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-08 16:45:14] |
Order Types: Stop Orders on the CME I referred to this and then I tried to check the price2 in trade orders so It should still in most cases execute like a stop market order right ? |
[2024-07-08 18:13:06] |
It is a Stop-Limit order. Refer to the following: Order Types: Stop-Limit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-08 18:20:37] |
In this section it’s written that it is a safety feature implemented by cme. So i tried placing a buy stop order and then i checked the price2 which was stop price +12 points i believe.. so as per the 12 points is like a safety net, in almost all-cases other than in extreme volatility it should still execute like a stop market order… am I right? |
[2024-07-08 18:30:28] |
We can not say anything further than it is a "Stop-Limit" and we define the Stop-Limit order here: Order Types: Stop-Limit We have set this as User Discussion, should you want to get opinions from other users. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-09 07:00:09] |
Now that ill have to use client side MIT orders, are you guys able to shorten the name for this order? my trade menus width has become much wider now. Atleast if "market if touched" be shortened to MIT just like how it is for the server side MIT order. It would be great |
[2024-07-11 14:25:55] |
It's really unacceptable to not have MIT server side order type. I just had bad slippage with MIT client side order :/ You guys have had TETON from so long. I am thinking to switch to CQG or Rithmic |
[2024-07-11 14:36:23] |
You will definitely not have that order type with CQG server-side. And we would not recommend Rithmic.
[2024-07-11 14:42:03] |
I know you guys dont recommend Rithmic, thats why i never even considered it as an option but not having MIT order is really unacceptable. I can visually see the delay with MIT client side order, the delay is understandable it being a client side order but server side MIT is very much needed. |
[2024-07-25 10:19:08] |
So now that I am using Teton, Today I had a power cut and so i tried the web based interface to trade from my mobile phone but its a lengthy process to log in and if I switch to some other app from the browser it would disconnect me and I would have to log back in. Before this when I was using IBKR, they obviously have an app where it is much much faster to log in and trade, etc. |
