Date/Time: Wed, 16 Sep 2026 06:30:29 +0000
Is it possible to exit drawing tool by right clicking?
View Count: 423
| [2024-06-25 15:48:00] |
| User429142 - Posts: 49 |
The way it currently works is I have my Chart calculator active and I use it to see the data I want between two points. I then right click and it disappears, great. However, that chart calculator still remains active so when i click on the chart again its still the chart calculator. I was hoping when I right clicked it would close the chart calculator and revert back to pointer or previously used option (crosshairs, hang, etc) I searched before posting this and a post about this in 2018 said it was something that will be included in later versions of the software. reference: right click to exit drawing So I'm hoping by now it is possible to do. |
| [2024-06-25 17:52:12] |
| John - SC Support - Posts: 47903 |
Refer to the following: Chart Drawing Tools: Right Click Exits Current Drawing Tool To (Global Settings >> Tool Settings >> General >> Tool Options) It is not exactly what you want, but if you right click twice while doing the drawing, then it will put you to the selected tool in the setting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
