Date/Time: Tue, 04 Nov 2025 16:32:23 +0000
Unable to connect to Rithmic apex server.
View Count: 491
[2024-06-22 06:11:35]
User188445 - Posts: 11
I am unable to conenct t rithmic data service. I have logged into Rtrader pro and put my login into sierra as well.
[2024-06-24 14:13:36]
John - SC Support - Posts: 42755
Reconnect to the data feed:
[2024-06-25 05:39:54]
2024-06-25 05:37:20.233 | Software version: 2627 64-bit
2024-06-25 05:37:20.233 | Primary Thread ID: 16896
2024-06-25 05:37:20.233 | Usage end date: 2024-07-04
2024-06-25 05:37:20.233 | Enabled for: Advanced Features 2.
2024-06-25 05:37:20.233 | Enabled for: Sierra Chart Historical Data Service.
2024-06-25 05:37:20.233 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-06-25 05:37:20.233 | Enabled for: Delayed Denali Exchange Data Feed.
2024-06-25 05:37:20.233 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-06-25 05:37:20.233 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-06-25 05:37:20.233 | Custom symbol settings values: enabled
2024-06-25 05:37:20.233 | Chart Update Interval: 500
2024-06-25 05:37:20.233 | Intraday Data Storage Time Unit: 0
2024-06-25 05:37:20.233 | Time Zone: +00:00:00 (UTC+00)
2024-06-25 05:37:20.233 | 2024-06-25 05:37:20 Local computer time in UTC
2024-06-25 05:37:20.233 | 2024-06-25 05:37:20 Local computer time in SC Time Zone
2024-06-25 05:37:20.233 | Program path: C:\SierraChart\
2024-06-25 05:37:20.233 | Data Files path: C:\SierraChart\Data\
2024-06-25 05:37:20.234 | OS Version Number: 10.0
2024-06-25 05:37:20.234 | Locale Setting: C
2024-06-25 05:37:20.234 | DLLs: ClusterChart.X64.dll, ClusterChart.X86.dll, ClusterVolume.X64.dll, ClusterVolume.X86.dll, OrderFlowsTrader.X64.dll, OrderFlowsTrader.X86.dll, UserContributedStudies_64.dll
2024-06-25 05:37:20.234 | Allowed protected custom studies:
2024-06-25 05:37:20.234 | Crash reporter started: true
2024-06-25 05:37:20.234 | | Number times message added: 1
2024-06-25 05:37:20.758 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:20.758 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:20.758 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:20.758 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:20.773 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:20.773 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:20.773 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:24.787 |
2024-06-25 05:37:24.788 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:24.788 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:24.788 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:24.788 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:24.818 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:24.818 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:24.818 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:28.813 |
2024-06-25 05:37:28.813 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:28.813 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:28.813 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:28.813 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:28.833 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:28.833 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:28.833 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:28.863 | File >> Reconnect selected.
2024-06-25 05:37:28.863 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:28.863 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:28.863 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:32.878 |
2024-06-25 05:37:32.878 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:32.878 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:32.878 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:32.878 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:32.894 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:32.894 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:32.894 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:36.901 |
2024-06-25 05:37:36.901 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:36.901 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:36.901 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:36.901 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:36.915 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:36.915 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:36.915 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:40.933 |
2024-06-25 05:37:40.933 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:40.933 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:40.933 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:40.933 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:40.949 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:40.949 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:40.949 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:44.945 |
2024-06-25 05:37:44.945 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:44.945 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:44.945 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:44.945 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:44.975 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:44.975 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:44.975 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:49.002 |
2024-06-25 05:37:49.002 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:49.002 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:49.002 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:49.002 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:49.017 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:49.017 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:49.017 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:53.026 |
2024-06-25 05:37:53.026 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:53.026 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:53.026 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:53.026 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:53.042 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:53.042 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:53.042 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:57.042 |
2024-06-25 05:37:57.042 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:37:57.042 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:37:57.042 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:37:57.042 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:37:57.057 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:37:57.057 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:37:57.057 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:01.059 |
2024-06-25 05:38:01.059 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:01.059 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:01.059 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:01.059 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:01.075 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:01.075 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:01.075 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:05.079 |
2024-06-25 05:38:05.079 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:05.079 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:05.079 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:05.079 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:05.094 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:05.094 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:05.094 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:09.090 |
2024-06-25 05:38:09.090 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:09.090 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:09.090 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:09.090 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:09.105 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:09.105 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:09.105 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:13.104 |
2024-06-25 05:38:13.105 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:13.105 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:13.105 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:13.105 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:13.120 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:13.120 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:13.120 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:17.132 |
2024-06-25 05:38:17.132 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:17.132 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:17.132 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:17.132 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:17.147 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:17.147 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:17.147 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:21.171 |
2024-06-25 05:38:21.171 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:21.171 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:21.171 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:21.171 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:21.186 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:21.186 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:21.186 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:25.191 |
2024-06-25 05:38:25.191 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:25.191 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:25.191 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:25.191 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:25.208 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:25.208 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:25.208 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:29.209 |
2024-06-25 05:38:29.209 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:29.209 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:29.209 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:29.209 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:29.210 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:29.210 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:29.210 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:33.219 |
2024-06-25 05:38:33.219 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:33.219 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:33.219 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:33.219 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:33.234 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:33.234 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:33.234 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:37.242 |
2024-06-25 05:38:37.242 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:37.242 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:37.242 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:37.242 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:37.257 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:37.257 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:37.257 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:41.274 |
2024-06-25 05:38:41.274 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:41.274 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:41.274 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:41.274 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:41.290 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:41.290 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:41.290 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:45.291 |
2024-06-25 05:38:45.291 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:45.291 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:45.291 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:45.291 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:45.314 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:45.314 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:45.314 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:49.331 |
2024-06-25 05:38:49.331 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:49.331 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:49.331 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:49.331 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:49.347 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:49.347 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:49.347 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:53.340 |
2024-06-25 05:38:53.341 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:53.341 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:53.341 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:53.341 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:53.358 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:53.358 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:53.358 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:57.373 |
2024-06-25 05:38:57.374 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:38:57.374 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:38:57.374 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:38:57.374 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:38:57.389 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:38:57.389 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:38:57.389 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:39:01.387 |
2024-06-25 05:39:01.387 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:39:01.387 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:39:01.387 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:39:01.387 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:39:01.402 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:39:01.402 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:39:01.402 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:39:05.412 |
2024-06-25 05:39:05.412 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:39:05.412 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:39:05.412 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:39:05.412 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:39:05.413 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:39:05.413 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:39:05.413 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:39:09.424 |
2024-06-25 05:39:09.424 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2024-06-25 05:39:09.424 | Rithmic Direct - DTC | Remote address is not set.
2024-06-25 05:39:09.424 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-25 05:39:09.424 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-25 05:39:09.440 | DTC Client socket (0) | CloseSocket call.
2024-06-25 05:39:09.440 | Rithmic Direct - DTC | Disconnected.
2024-06-25 05:39:09.440 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
[2024-06-25 11:45:07]
Sierra_Chart Engineering - Posts: 21306
We want you to restart Sierra Chart and see if the problem is resolved.
[2024-06-25 15:45:28]
Also, please update to the latest release. There were some changes from Rithmic that require the latest release. Follow these instructions to update:
[2024-06-26 13:21:10]
I am getting
" Connection error message from service: Rithmic Direct - DTC Logon error recieved from server : permission denied "
[2024-06-26 13:27:40]
Refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
