Date/Time: Sun, 08 Sep 2024 00:28:52 +0000
I TRYED TO FIX THIS I CANT
View Count: 147
[2024-06-20 23:42:01] |
User143551 - Posts: 100 |
i got the 2 minute bars to open at the right time with the countdown clock , now i am getting when i log on to sierra charts i get a message log , teton cme orderrouting /marketdeoth supported I GET HUNDERD OF LINES IN PRINT ONE IS SYSTEM CLOCK ADJUSTMENT IS ENABLED SO ON AND SO ON I HAVE HOURS OF TRYING TO FIX THIS AND WOULD TAKE YOU TWO MINUTES TO FIX IT I NEED RAY OR SOME ONE TO HELP ME FIX THIS
[2024-06-20 23:43:11] |
ON THE PHONE
[2024-06-21 00:46:12] |
It sounds like you turned on the NTP client, but your Sierra Chart does not have permission to adjust your computer clock. This is not an issue and does not cause a problem. Select "Global Settings >> NTP Settings" and set the option for "NTP Client Enabled" to "No". Then select OK to close that window. If you continue to get strange messages, then we will need to see your Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
