Date/Time: Sun, 24 Nov 2024 07:00:52 +0000
Pane 2 can't be resized
View Count: 196
[2024-06-19 12:35:31]
TopGunTrader - Posts: 172
I wanted to created a normalized chart of how much stocks are above/below their rolling vwaps. Created it but it won't let me resize chart. Attached pic and 1 chart workspace.
imageCapture.PNG / V - Attached On 2024-06-19 12:33:53 UTC - Size: 39.92 KB - 41 views
attachmentPaneCan'tBeSized.Cht - Attached On 2024-06-19 12:34:56 UTC - Size: 4.37 KB - 198 views
[2024-06-19 12:51:23]
Added delta to another chart and have same problem can't resize pane 2. I put it in Pane 3 and same issue.
[2024-06-19 12:52:21]
Oddly previous panes in workspace bottom panes can be changed the white line shows up to move size but not on newer charts.
[2024-06-19 12:55:39]
If this helps scroll wheel which for all other charts moves bars/candles up and down doesn't work on new charts either.
[2024-06-19 15:08:29]
This is not really making any sense to us. There is no reason why these items would not be working in some charts and working in others, assuming the settings are the same and things are not locked out.
In particular, refer to the following regarding changing the size of a region:
Working With Charts: Chart Window and Regions
And with regards to the scroll wheel, make sure the scale is not set to "Interactive Scale Locked". Refer to the following:
Chart Scale and Scale Adjusting: Locking the Scale
[2024-06-19 16:03:04]
Thanks for help for some odd reason Interactive Scale Locked was selected on all new charts which prevented the school wheel, I couldn't adjust size of scale like I used to nor adjust bottom pane.
That fixed it thanks again! This was driving me nuts.
