Date/Time: Sun, 27 Sep 2026 08:20:57 +0000
is there no other way to install Sierra Chart?
View Count: 1108
| [2024-06-18 15:12:21] |
| User546735 - Posts: 1 |
I had installed the platform, but never used it... because I didn't I can't open it, something went wrong when loading.... I would love to have it, is there no other way to install it???? (original) J'avais mis la plateforme, mais jamais m'en servir... parce que je ne arrive pas à l'ouvrir,quelque chose ne pas bien ce passé au chargement.... Je aimerais bien l'avoir, n'y a pas une autre façon de l'installer ???? Le mar. 18 juin 2024, 02:01, Sierra Chart Support <support@sierrachart.com> a écrit : > Hello Ferreira Rui, > > The usage time on your Sierra Chart account, ruiferreira1967, will expire > on 2024-06-22. To avoid an interruption, activate a Service Package for > automatic renewal here: > https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation > > A new Sierra Chart account on a trial will require activation. For > instructions to activate, refer to: > > Sierra Chart Trial Account > > For help with getting started with Sierra Chart, refer to the Getting > Started page: > Getting Started, Opening Charts and Basic Trading > > To view helpful videos for Sierra Chart usage, refer to: > Video Library > > Follow the link below to stop account reminders for 2 weeks: > https://www.sierrachart.com/OptOut.php?MuteReminders=334483 > > Thank you, > Sierra Chart Support > > |
| [2024-06-18 16:13:32] |
| John - SC Support - Posts: 48028 |
The main installer is available by selecting the following link: https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe There is also a Zip Installer that can be used if you are having problems with the regular installer. Refer to the following: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-07-08 15:23:25] |
| Sierra_Chart Engineering - Posts: 24983 |
To uninstall Sierra Chart refer to: Software Download: Uninstalling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
