Date/Time: Sun, 08 Sep 2024 01:34:55 +0000
Time to next candle TR
View Count: 159
[2024-06-17 19:11:22] |
rededge - Posts: 1 |
What I notice, TR: is stock if price is not moving also TR is different on different charts but they are have the same time frame 5min. I have 12 charts link by time 5min and TR is different on each of them and is not counting down. How to fix that. ? |
Private File |
[2024-06-17 19:22:38] |
You need to keep in mind how the charts are updated. In general, the charts are updated according to the "Chart Update Interval". But if there are no trades occurring, then there will not be an update. As such, the Countdown Timer will not update until there is another trade. As such, seeing a difference of a few seconds would not be unusual and is not something to be concerned about. Refer to the following: General Settings Window: Chart Update Interval (Global Settings >> General Settings >> General >> Update Intervals) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
