Date/Time: Sun, 24 Nov 2024 07:37:33 +0000
Can't update Sierra software
View Count: 208
[2024-06-14 13:49:28] |
jms - Posts: 3 |
Good morning, I am about to send you a log file of a failed attempt to update the software. I continue to get errors regarding the update on my laptop. Please help. Thank you, Jose |
[2024-06-14 16:01:48] |
Your log shows the following error: Error opening C:\Users\jmsem\Downloads\SierraChart2629\SierraChart_64.exe. Windows error code 32: The process cannot access the file because it is being used by another process.
Error encountered with file move. Retrying in 2 seconds. This means that you have Sierra Chart running while you are trying to do the update. Make sure you exit out of any sub-instances that you may have running before you start the update. And it is best if you start the update from the Main Instance by selecting "Help >> Download Current Version". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-15 21:50:06] |
Sierra_Chart Engineering - Posts: 17154 |
We also do not recommend putting Sierra Chart in this location: C:\Users\jmsem\Downloads\SierraChart2629\ We recommend the default location of C:\SierraChart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
