Date/Time: Sun, 24 Nov 2024 07:48:21 +0000
Market Level 2 Data not showing
View Count: 229
[2024-06-14 09:47:24] |
User371762 - Posts: 5 |
Hello i have access to Markt Level 2 Data through my Topstep account, when i use it on Bookmap it works fine. But when i try it on Sierra Chart nothing shows. No DOM and no Heatmap. It shows maybe 2 Lines during few hours but thats it, but a friend of mine also uses the Heatmap on Sierra and works everythings works fine, we have the same settings. What is the Problem? I will attach the sierra screen link. https://www.sierrachart.com/image.php?Image=1718358147802.png Dont know why the DOM is not showing, but i can only see the numbers, one above the price and one under. Best Regards |
[2024-06-14 15:20:28] |
You are not getting the data from Rithmic, you are getting the data through us. And you do not have an exchange active that includes the Market Depth. Right now, you have the following exchange active: - Full CME Group (CME, CBOT, COMEX, NYMEX) for Non-Professional Trading Accounts You need an exchange that includes the Market Depth. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Adding Support for CME Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
