Date/Time: Sun, 08 Sep 2024 00:38:38 +0000
Problem with depth of market on DOM (Replay)
View Count: 204
[2024-06-04 22:49:09] |
User368075 - Posts: 15 |
When I use the DOM in replay mode (I followed all the instructions, is not the first time I use the REPLAY mode on DOM) I never had any problem. Right now the DEPTH is not aligned with the current price. See attachment
[2024-06-07 12:20:29] |
Any idea?
[2024-07-03 13:52:13] |
Sierra_Chart Engineering - Posts: 16292 |
Make sure that chart is set to load the number of days sufficiently high enough to go back to the Date being replayed. Refer to: Chart Settings: Load Data Limiting Method (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) And re-download the market depth data for the date-time range being replayed: Market Depth Historical Graph: Downloading Of Historical Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
