Date/Time: Sun, 24 Nov 2024 10:59:25 +0000
Curent Bid/ask volume
View Count: 213
[2024-06-04 17:02:42] |
hamboz - Posts: 16 |
My current traded bid and ask volume on the DOM is scrunched up, how can I fix it? I have my tick size set up to 1. Look at the attachment
Scrunched.PNG / V - Attached On 2024-06-04 17:02:25 UTC - Size: 144.36 KB - 47 views |
[2024-06-04 19:10:00] |
We do not have support for combining the Current Traded Bid/Ask. You can use the "Market Depth Combine Increment In Ticks" for the main Bid/Ask Market Depth and apply that to the Recent Bid/Ask volumes. But not any of the other columns at this time. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Chart Settings: Apply Combine Increment in Ticks to Recent Bid/Ask Volume Columns (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-04 19:43:16] |
I don't want to combine. I just want to make it clearly visible. If you see my attachment, current bid/ask volume numbers are scrunched up so how can i fix it?
[2024-06-04 20:28:31] |
The reason they are "scrunched" up and the others are not is because you have used the "Market Depth Combine Increment in Ticks" for the Market Depth and you have either changed the Tick Size or the Volume at Price Multiplier which affects the Numbers Bars data. Since the Current Traded columns do not have a way to combine the data, you are seeing the data at every tick. The only option available is to modify the scale so you can see those values. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
