Date/Time: Tue, 22 Apr 2025 18:11:40 +0000
Having trouble connecting to data feed
View Count: 515
[2024-06-03 19:15:39]
User567678 - Posts: 3
The message log is giving me a error connecting to data or trade service. i have had this issue for about 2 hrs i have tried restarting and disconnecting from the data feed and reconnecting to the data . Also reset my pc to see if that would help but it hasnt.
[2024-06-03 20:12:29]
Sierra_Chart Engineering - Posts: 19305
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2024-06-03 20:18:15]
2024-06-03 13:16:44.725 | Software version: 2625 64-bit
2024-06-03 13:16:44.725 | Primary Thread ID: 10212
2024-06-03 13:16:44.725 | Usage end date: 2024-06-12
2024-06-03 13:16:44.725 | Enabled for: Advanced Features 2.
2024-06-03 13:16:44.725 | Enabled for: Sierra Chart Historical Data Service.
2024-06-03 13:16:44.725 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-06-03 13:16:44.725 | Enabled for: Delayed Denali Exchange Data Feed.
2024-06-03 13:16:44.725 | Enabled for exchange2: CME
2024-06-03 13:16:44.725 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-06-03 13:16:44.725 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-06-03 13:16:44.725 | Custom symbol settings values: enabled
2024-06-03 13:16:44.725 | Chart Update Interval: 500
2024-06-03 13:16:44.725 | Intraday Data Storage Time Unit: 0
2024-06-03 13:16:44.725 | Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00)
2024-06-03 13:16:44.725 | 2024-06-03 20:16:44 Local computer time in UTC
2024-06-03 13:16:44.725 | 2024-06-03 13:16:44 Local computer time in SC Time Zone
2024-06-03 13:16:44.725 | 2024-06-03 20:14:19 Server time in UTC
2024-06-03 13:16:44.725 | Local computer UTC time and Server UTC time difference: 0 seconds.
2024-06-03 13:16:44.725 | Program path: C:\SierraChart\
2024-06-03 13:16:44.725 | Data Files path: C:\SierraChart\Data\
2024-06-03 13:16:44.725 | OS Version Number: 10.0
2024-06-03 13:16:44.725 | Locale Setting: C
2024-06-03 13:16:44.725 | DLLs: MyStudies_64.dll, OldMyStudies_64.dll, TraderOrderFlowV3_64.dll, UserContributedStudies_64.dll
2024-06-03 13:16:44.725 | Allowed protected custom studies:
2024-06-03 13:16:44.725 | Crash reporter started: true
2024-06-03 13:16:44.725 | | Number times message added: 1
2024-06-03 13:16:46.916 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-06-03 13:16:46.916 | Rithmic Direct - DTC | Remote address is not set.
2024-06-03 13:16:46.916 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-03 13:16:46.916 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-03 13:16:46.934 | DTC Client socket (0) | CloseSocket call.
2024-06-03 13:16:46.934 | Rithmic Direct - DTC | Disconnected.
2024-06-03 13:16:46.934 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-03 13:16:50.933 |
2024-06-03 13:16:50.933 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-06-03 13:16:50.933 | Rithmic Direct - DTC | Remote address is not set.
2024-06-03 13:16:50.933 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2024-06-03 13:16:50.933 | Select 'File >> Disconnect' to prevent further connection attempts.
2024-06-03 13:16:50.946 | DTC Client socket (0) | CloseSocket call.
2024-06-03 13:16:50.946 | Rithmic Direct - DTC | Disconnected.
2024-06-03 13:16:50.946 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
[2024-06-03 20:36:46]
John - SC Support - Posts: 39416
Please update to the current version to fix this. Follow these instructions:
[2025-01-04 21:45:15]
ralphdavies01 - Posts: 3
Hello, I am also facing trouble connecting to a data feed. I am using Rithmic Direct - DTC with Topstep Trader-Europe-Non-Aggregated settings.
I was able to connect perfectly fine yesterday and I have checked that I have no issues getting data when I log on directly to R Trader Pro, so I am unsure of what more steps to follow.
I have just sent my message log for analysis at 21:42 (GMT).
Any help would be greatly appreciated.
[2025-01-04 22:46:58]
We looked at the Message Log and this is what is applicable:
Data/Trading Service Connection and Symbol Issues: 1.7. Unable to Connect Because Server is Not Available over the Weekend
For now:
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
Date Time Of Last Edit: 2025-01-04 22:47:07
