Date/Time: Sun, 24 Nov 2024 11:04:02 +0000
Live feed hookup for trading
View Count: 207
[2024-06-03 19:03:34]
User935845 - Posts: 3
Can someone at Sierra help me? I cannot figure things out. I have read through many pages Sierra Chart documentation over 3 days and getting more confused each day. I just want to get connected up and trade. That is all!
Here is what I have done:
1) I opened an account with Sierra chart.
2) I funded and bought 3 months of package 12
3) I activated the Denali Exchange Data feed
4) I picked and activated the CME exchange fee with depth of trading. The 12.50 per month exchange data feed.
5) I called AMP with whom I have my funded trading account. They set it up for teton trading. And they said that Sierra updates once per day at noon and in just a few minutes the update would happened.
6) i waited. It is now 1:20 pm central time. Still no live feed connection.
7) when I try to connect it say no trading account assigned.
8) I went to my account in Sierra Data/Trade services picked first Sierra Data all. That only gives me delayed data.
I went back to Data/trade services and selected teton.
What should be selected under Data/Trade services? Sierrs Data All or teton? Which one?
I am so confused about what to do.
Please help!
[2024-06-03 20:23:03]
Your "Current Selected Service" should be set to "Teton CME Order Routing". Everything else on your account looks good.
Follow the instructions at the following link starting at Step #6:
Sierra Chart Teton Futures Order Routing: Setup Instructions
We have no idea why AMP made the statements they made about us updating only once a day at noon. This is not correct at all. Once AMP finishes the setup for your account, then you are fine to connect.
If you still have a problem connecting after going through the above instructions, then refer to the following:
Sierra Chart Teton Futures Order Routing: Common Mistakes
And if you then still have an issue, then let us know and we will help from there.
[2024-06-04 03:08:03]
When I contacted AMP and they were walking me through the set up they showed and SAID that Sierrachart had 2 platforms with them. Here is exactly what they showed me on the AMP client portal that I could pick from.
First one was: Teton (Sierra Chart)
Second one was: Sierra Chart - Denali - CQG (No Data - Order Routing only)
I picked the first one above. I hope that is the correct one??
Later today I did see my balance of my AMP account show up from within Sierra Chart so I am now assuming all is ready to trade??
I also selected Teton CME order routing from within Sierra Chart as my current selected service. I will try a test trade tommorrow.
[2024-06-04 14:06:29]
If you are only trading the CME Group, then using Teton is our recommendation.
It sounds like you have everything setup correctly.
