Date/Time: Wed, 23 Sep 2026 05:51:56 +0000
Not understanding why some chart symbols can get Intraday data & others not.
View Count: 1507
[2014-08-19 21:57:38]
inthetrend - Posts: 33 Invalid SC Account Name.
I can get Intraday data for DXU14 & EUU14 for example, but with ESU14 or ES#, only Historical is available. How can I get the latter symbols (and others) with Intraday data?
I have two futures trading accounts on two other PC's, though not on the subject platform which has SC Exchange data.
Second question: I searched on "non-CLR version" but do not see how it differs (only technical questions about it's handling of spread sheets. Is this the long-planned "non-.Net" version? If so, I would like to learn about it and likely make a switch. Could you provide a link where I could learn more? Thanks.
[2014-08-19 23:18:25]
ES# will not work with Intraday charts.
For the other symbol we need to see the Message Log after opening a chart for that symbol.
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
The only thing to know about the non-CLR version is that it has the new Sierra Chart spreadsheets. This is all.
[2014-08-20 22:26:50]
Here is the log requested. It does show I have no futures account registered, but I really do have one...just not on this PC. Is there a way to satisfy this condition by registering my AMP account somewhere?
Software version: 1141 | 2014-08-20 14:06:52
Usage end date: 2014-09-11 | 2014-08-20 14:06:52
Enabled for: Advanced Features. | 2014-08-20 14:06:52
Enabled for: Sierra Chart Historical Data Service. | 2014-08-20 14:06:52
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-08-20 14:06:52
Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-08-20 14:06:52
Enabled for: DOW INDEXES exchange. | 2014-08-20 14:06:52
Enabled for: S&P INDEXES exchange. | 2014-08-20 14:06:52
Enabled for: CBOE INDEXES exchange. | 2014-08-20 14:06:52
Enabled for: NASDAQ INDEXES exchange. | 2014-08-20 14:06:52
Enabled for: US EQUITIES exchanges. | 2014-08-20 14:06:52
Received 1 data feed usernames. | 2014-08-20 14:06:52
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-20 14:06:52
Active service: SC Exchange Data | 2014-08-20 14:06:52
Time Zone: -07:00:00 (MST-07) | 2014-08-20 14:06:52
2014-08-20 14:06:52 Local computer clock time | 2014-08-20 14:06:52
2014-08-20 21:06:52 GMT time | 2014-08-20 14:06:52
2014-08-20 14:06:52 Time zone adjusted time | 2014-08-20 14:06:52
Time difference to server time: 8 seconds. | 2014-08-20 14:06:52
Program path: C:\SierraChart2\ | 2014-08-20 14:06:52
Data Files path: C:\SierraChart2\Data\ | 2014-08-20 14:06:52
OS Version Number: 6.1 | 2014-08-20 14:06:52
Checking for new symbol settings for scbcd | 2014-08-20 14:06:52
Symbol settings are up-to-date for scbcd | 2014-08-20 14:06:52
NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2014-08-20 14:06:57
SC Exchange Data: Connected. | 2014-08-20 14:06:57
SC Exchange Data - Starting real-time market data updates for: ES#. ID: 1 | 2014-08-20 14:10:15
SC Exchange Data: Subscribing to market data in the service client is not supported. Symbol: ES# | 2014-08-20 14:10:15
HD Request # 2 - Downloading Historical Daily chart data for ES#. Starting date: 2014-08-18. Service: scbcd | 2014-08-20 14:10:15
HD Request # 2 - Using user Barchart Historical data account. | 2014-08-20 14:10:15
HD Request # 2 - Requesting historical Daily Continuous data for ESZ10 starting at 2014-08-17 | 2014-08-20 14:10:15
SC Exchange Data - Starting real-time market data updates for: MNU14. ID: 2 | 2014-08-20 14:10:15
SC Exchange Data: Subscribing to market data in the service client is not supported. Symbol: MNU14 | 2014-08-20 14:10:15
SC Exchange Data - Starting real-time market data updates for: ESU14. ID: 3 | 2014-08-20 14:10:15
SC Exchange Data: Subscribing to market data in the service client is not supported. Symbol: ESU14 | 2014-08-20 14:10:15
[2014-08-20 22:33:03]
By the way, I use Sierra Charts on two other PC's to trade futures. I am sure your system has records of this. Why not cross-check them, and satisfy CME regs that I should be entitled to get futures RT intraday data on the third PC. Thank you.
PS. If I were connected to a live account with this PC, I would be able to get the broker's feed directly and would not have to use your exchange data.
[2014-08-21 00:52:33]
In the copy of Sierra Chart that you posted this Message Log from, update it by selecting Help >> Download Current Version.
By doing that when using SC Exchange Data you will now be able to get historical Intraday data for CME futures.
To get the real-time CME futures data at the reduced exchange fees, requires that you set Sierra Chart to use one of the supported futures trading services. This is how it works.
[2014-08-21 16:30:10]
Ok, that moved the ball, but not enough to get the data. Here is the log:
HD Request # 7 | Downloading Intraday chart data for ESU14 to the file ESU14.scid. Service: scbcd | 2014-08-21 08:58:51
HD Request # 7 | Download start Date-Time: 2014-02-16 08:58:51.0 | 2014-08-21 08:58:51
HD Request # 7 | Using server: scdf1.sierracharts.com port 10149 | 2014-08-21 08:58:51
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-21 08:58:51
Socket (1132) | Connected. | 2014-08-21 08:58:52
HD Request # 7 | Sending historical data logon request message. | 2014-08-21 08:58:52
Socket (1132) | Shutdown and closed. | 2014-08-21 08:58:52
The network socket for historical data has been closed. | 2014-08-21 08:58:52
HD Request # 7 | Error downloading historical Intraday data for ESU14. Historical data logon error: Invalid/missing data for service code: scbcd | 2014-08-21 08:58:52
HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU14 | 2014-08-21 08:58:52
HD Request # 7 | Intraday download COMPLETE for ESU14. Completion time: 1s | 2014-08-21 08:58:52
Real-time Intraday chart data file updates started for ESU14 | 2014-08-21 08:58:52
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\ESU14.scid | 2014-08-21 09:09:46
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\ESU14.scid | 2014-08-21 09:10:25
[2014-08-21 17:16:46]
This problem will be solved in the next release. This will be version 1176 coming out today.
