Date/Time: Sun, 24 Nov 2024 14:49:32 +0000
barre d'outil non connecter avec les graphique détaché
View Count: 180
[2024-05-20 17:24:14] |
User913209 - Posts: 7 |
bonjour j'ai un problème a chaque fois que je sélectionne un outils ou autres dans ma barre de contrôle , les outils tel que les ligne rectangle ou autre ne fonctionne pas sur les graphique détaché de la fenêtre , comment faire la modification ? ce problème est survenue ils n'y a pas longtemps et impossible de trouver le remède help me please
[2024-05-20 20:55:25] |
From Google Translate: hello I have a problem every time I select a tool or other in my control bar, tools such as rectangle lines or others do not work on graphics detached from the window, how to make the modification? this problem occurred not long ago and impossible to find the remedy help me please
Since this is a Detached window, if you have the option for "Tools >> Tool Settings >> General >> Use Common Drawing Tool for Charts" set to "No", then you have to select the drawing tool you want on the actual chart you are wanting to draw on. If you want to use a Control Bar, then you would need to have that control bar be associated with that detached window (on the detached window select "Window >> Control Bars >> Control Bar n" to have a control bar attached to that chart window. Refer to the following: Chart Drawing Tools: Use Common Drawing Tool for Charts (Global Settings >> Tool Settings >> General >> Tool Options) Control Bar: Window >> Control Bars >> Control Bar [1-12] For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
