Date/Time: Sun, 24 Nov 2024 14:57:54 +0000
Zig Zag Reversal Timestamp.
View Count: 255
[2024-05-17 21:13:25] |
beanthehacker - Posts: 31 |
Hi, How can I access the values of Zig Zag study's "Display Time Labels" option when that option is set to Yes? In spreadsheet I see the column is always 0.0 (Text Labels, SG2?) and on the chart I see the timestamp of reversal is displayed correctly. Thank you. |
[2024-05-19 14:05:05] |
When you have the Zig Zag Input for "Display HH, HL, LL, LH Labels" set to "Yes", then in the Spreadsheet Study you will have a number that represents that label in the column for the "Text Labels". You should definitely have have a 0 at the bar where the label is listed. Then you can get the time of bar where that label is displayed by looking at the Column A values. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-20 04:32:04] |
Thanks John, is there any way to access the timestamp of last reversal directly (say in ASCIL), or have it populated in one of the columns of spreadsheet? If not, what sort of formula can I use to have it available in one of the empty columns in case you can help with that or a similar example please? |
[2024-05-20 14:43:47] |
Whatever you do, you have to put some logic into finding that particular reversal. For the spreadsheet, there is an example at the following link: Spreadsheet Example Formulas and Usage: Return Last Two Zig Zag Reversal Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
