Date/Time: Tue, 04 Nov 2025 09:04:21 +0000
replay backtest order Not filled !
View Count: 513
[2024-05-08 14:53:19]
User185210 - Posts: 67
Hello, I am not able to have any order filled during a replay backtest.
I am using SC2634 + IB.
When I set IB on sim + sc data feed denali live, the spreadsheet for trading is sending the order to IB sim and it works very well. My only issue is that the time is not accelarated!
Reason why I would like to use the SC backtest to speed up the time and get the stats results.
I have read most of the docs on SC for replay, backtest and still do not manage to have the order sent to sim1 in sc!
Could anyone help me out?
Thank you for your help.
Paul
[2024-05-08 15:17:05]
John - SC Support - Posts: 42737
Refer to the following:
Auto Trade System Back Testing: Differences Between Back Testing and Real-Time Auto Trade System Evaluation
[2024-05-08 16:17:26]
Hello John,
I just changed the spreadsheet system for Trading setup to "signal only on bar close", have tick by tick data, depth downlowded ... and still no result!
Do you have by any chance a working test example of chartbook with a spreadsheet for trading I could try to adjust from there my system ?
Or is there a sim account setup to be made!
thank you
[2024-05-09 14:51:57]
Sierra_Chart Engineering - Posts: 21299
The first thing is to make sure that the spreadsheet automated trading system, is giving an order signal from the buy and sell entry columns. If there any rejections check the Trade >> Trade Service Log.
