Date/Time: Sun, 24 Nov 2024 18:26:48 +0000
Different Font sizes X Y Axis?
View Count: 180
[2024-05-03 13:30:08] |
User993067 - Posts: 156 |
I don't see an option to separate the font or size or for the X and Y axis. It is also the same font and size as the trade DOM. In the trade DOM I need bigger font, but don't want the same size for charts especially on the X and Y axis... Also would like a separate font for numbers bars, as the font I need for the DOM is thicker, and that makes it difficult to read numbers bars no matter how I scale the max min on the numbers bars sizing. is there an option I am missing? Please advise... |
[2024-05-03 15:08:44] |
There is no option to have a different font for the X and Y axes. These are both controlled through the "Chart Text" font. You can have a different font in your Trading DOM, as this is a separate chart altogether. As such, you can use the chart specific graphics settings for the Trading DOM and set the font as you like. Refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts You can not change the font style for the Numbers Bars study, this also uses the "Chart Text" font. But you can change the font size. Refer to the following: Numbers Bars: Font Size and Style for Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
