Date/Time: Sun, 24 Nov 2024 19:59:21 +0000
[FEATURE REQUEST] - Market Depth Historical Graph
View Count: 269
[2024-05-03 08:50:48]
VLiviu - Posts: 223
Hi SC team,
Please add the ability to set Highest/Lowest quantity for coloring per session. (day and night)
During the day, the volume is bigger so we set specific values and during the night the graph should pick different values.
[2024-05-03 15:13:33]
This is already supported. Refer to the following:
Market Depth Historical Graph: Determine Min and Max Levels from All Bars or Visible Bars
[2024-05-03 15:35:04]
VLiviu - Posts: 223
ah, I see!
so, during the day (normal trading hours) I select ALL BARS,and during the evening hours I select Day/Evening Sessions?
[2024-05-03 15:48:16]
cesium - Posts: 85
Piggybacking on this support thread, ability to completely turn colors off and only graph numbers? Have not located this ability or a trick to make it happen
Logic use case being colors cover up chart grid lines even when colors sets to chart background color in attempt to hide color
Date Time Of Last Edit: 2024-05-03 15:48:47
[2024-05-03 16:46:05]
No, you select "Day/Evening Sessions" at all times. Then as long as you are using a Percentage of Maximum to determine your Highest and Lowest values for coloring, then the Maximum value that will be used will be the maximum value for the Day session during the Day session and the maximum value for the Evening session will be from the Evening session.
Date Time Of Last Edit: 2024-05-05 20:08:03
[2024-05-03 16:49:40]
Set the colors to be the same as the background color and you will not be able to view the coloring.
[2024-05-05 17:28:00]
cesium - Posts: 85
Thank you would also like to add doing the above combined with
Chart Settings >> Draw Highlight Drawings Underneath Main Graph and Studies set to NO
achieved the behavior I desired, for others looking to achieve the same thing
