Date/Time: Mon, 21 Apr 2025 04:38:30 +0000
Constantly disconnecting, freezing and unable to update - in Thailand.
View Count: 1108
[2024-05-17 13:38:09] |
Sierra_Chart Engineering - Posts: 19285 |
We would expect it to be done within five weeks. Update: The new ISPs we now have fully provisioned and will automatically be used by Sierra Chart. Although only for CME data at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-01 14:30:28
[2024-06-01 03:49:21] |
Deucalion - Posts: 32 |
Refer to Sticky: Sierra Chart Internet Connectivity Related Issues What server (until Southfield is online), should I be using in THailand? DS13 / D21 / DS27 or DS32? Date Time Of Last Edit: 2024-06-01 03:50:32
[2024-06-01 14:29:26] |
At this point use either of these two servers: DS27.sierracharts.com or DS32.sierracharts.com We would fully expect the connectivity issues to be resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-05 12:45:12
[2024-06-28 11:21:37] |
From your sticky, is this resolved as best as you could. And what servers may I use in Thailand? Thanks
[2024-06-28 14:19:21] |
For CME data probably would be best to use DS13.SierraCharts.com. Change this setting and the following one: Sierra Chart Server Settings: CME Exchange Data Feed Server Address and Port Override (Global Settings >> Sierra Chart Server Settings >> General >> Special) If you still have issues, let us know and we will set up another relay point in the Pacific. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-28 14:54:24] |
Ok, thanks will do
[2025-03-05 17:13:48] |
hello support - can you tell what server is best to use in Thailand for CME Realtime futures after you resolved the situation from last year with your ISP currently I am not using anything specific ...the server field is left open (default) |
[2025-03-06 19:44:03] |
We recommend using the New Zealand server if you are having a problem with US servers: Denali Exchange Data Feed: Europe and Asia Pacific Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
