Date/Time: Tue, 04 Nov 2025 14:40:52 +0000
How to display aggregated data in the attached DOM as per the scale of the chart
View Count: 621
|   [2024-04-29 21:28:58]     |
| User130696 - Posts: 104 |
                Hello, Please look at the screenshot. How cam we automatically aggregate the DOM data as we scale up or down the associated chart? In order to see the NQ chart, DOM is invisible due to shrinking down to merely a line. Thanks,  |
|   [2024-04-30 13:44:57]     |
| John - SC Support - Posts: 42747 |
                We do not understand the question. Please give us more information on what you are referring to.
                 For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2024-04-30 17:55:32]     |
                Instruments such as NQ and other volatile assets do not perform well in candlestick charts in the lower timeframe of 30 seconds or 1 minute with the DOM on. If you want to see DOM then you cannot see the chart well, if you want to see DOM well then yu cannot see the chart well. Please see my screenshot again to understand. Out of two scenarios, I am attaching screenshot for the second scenario. First scenario screenshot is there in my previous post. Rather than this, when scale is in interactive mode, the data in the dom should be following the price scale and show aggregated data at different scale levels in the increment of the tick of the corresponding instrument. Date Time Of Last Edit: 2024-04-30 18:00:10
|   [2024-04-30 18:43:18]     |
                There is not an option to have the Market Depth aggregate or de-aggregate as the scale is adjusted. But you can set a single value that defines the number of ticks to aggregate. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) This can also be applied to the Recent Bid/Ask volumes. Refer to the following: Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2024-04-30 20:29:45]     |
                This is fine, thanks.
