Date/Time: Sun, 05 May 2024 05:27:50 +0000
Pitchfork display error
View Count: 2160
[2013-05-07 04:11:07] |
User46869 - Posts: 4 |
I have found a large error in the drawing of the median line of an Andrews pitchfork, which disappears after scrolling a couple of bars. The parallels are drawn correctly. I think this is a different issue to the earlier report of inaccurate drawing. There are enough bars between the pivots to get a reasonably accurate drawing. http://www.sierrachart.com/image.php?l=1367899432109.png http://www.sierrachart.com/image.php?l=1367899503932.png http://www.sierrachart.com/image.php?l=1367899851187.png |
[2013-05-07 05:05:00] |
This does not seem like it should happen. We will look into it.
[2013-05-07 05:16:17] |
I found that the A bounces around a lot if I scroll when the last bar on the right is near the B-C mid point. Further away from the mid it settles down.
[2013-05-07 07:13:35] |
Could you provide the Chartbook containing the chart with this Pitchfork drawing. The Chartbook only needs to contain one chart. Here are the instructions to attach the Chartbook: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-07 11:48:33] |
I have attached the chartbook. Do you also need the data file? It's historical data from 2007.
bug.cht - Attached On 2013-05-07 11:47:25 UTC - Size: 17.69 KB - 551 views |
[2013-05-07 15:28:53] |
Al SC Developer - Posts: 434 |
We have reproduced this and it will be addressed in ver 972 when available.
Date Time Of Last Edit: 2013-05-07 16:04:06
