Date/Time: Sat, 18 May 2024 13:22:37 +0000
Symbol for Nasdaq Decline Volume Market Internals Data feed
View Count: 122
[2024-04-24 16:16:10] |
User130696 - Posts: 62 |
Hello, What is the working Symbol for Nasdaq Decline Volume Market Internals Data feed ? Thanks Date Time Of Last Edit: 2024-04-24 18:20:00
[2024-04-24 16:32:34] |
All of the information on the Market Statistics symbols is here: Sierra Chart Market Statistics: Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-24 18:26:27] |
If thats true then why is chart saying NaN ? Please see the screenshot for DVOL for Nasdaq. Also what the symbols for sugar, coffee and gasoil ? |
Screenshot 2024-04-24 at 2.23.16 PM.png / V - Attached On 2024-04-24 18:24:51 UTC - Size: 234.77 KB - 23 views |
[2024-04-24 18:36:00] |
User61168 - Posts: 351 |
my 2 cents.. no idea why this happens but doubleclicking the "NaN" in chart region price column resolves the issue 99% of the time. Edit: I think it's got something to do with value format so play around with different formats also resolves this issue..just trying to help Date Time Of Last Edit: 2024-04-24 18:38:05
[2024-04-24 19:23:17] |
yes, it did but I do see that the incoming data stopped after 2:21 PM EST
Screenshot 2024-04-24 at 3.22.30 PM.png / V - Attached On 2024-04-24 19:22:47 UTC - Size: 51.98 KB - 26 views |
[2024-04-24 23:02:47] |
We are not seeing any issue with the data for DVOL-NQ. The data goes to 16:30 Eastern US Time. Try opening a separate chart for that symbol and make sure you are getting what you expect. If the new chart is correct and the Add Additional Symbol is still not showing properly, then reload the chart with the Add Additional Symbol by selecting "Edit >> Reload and Recalculate". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-25 05:38:46] |
Hello, I will check tomorrow morning; currently, at about 1:35 am EST, I can see the update till 5:57 pm EST. |
[2024-04-27 16:15:35] |
Thus is resolved thanks
