Date/Time: Mon, 20 May 2024 07:42:34 +0000
Parent Target quantity
View Count: 79
[2024-04-23 19:26:22] |
User668089 - Posts: 7 |
Hello, I'd like to ask why my limit for target's in a parent is less then 3, and if i can configure it to be more in my App? Kind Regards, Pawel Korczyk. |
[2024-04-23 19:46:35] |
John - SC Support - Posts: 31734 |
We are not sure what you are referring to. The one thing we want to point out is that the attached orders quantity will be 0 if the parent order has not filled. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-23 19:59:15] |
I would like to open a transaction with 3 target's, but can only open it with 2, how do i increase the limit on one transaction.
[2024-04-23 20:35:17] |
You can have up to 8 targets in an Attached Order Configuration. On the Trade Window under the "Targets" tab, you select the button for "Add" to add as many targets/stops as you want. By default, the first entry will be a Target, then the second entry will be a Stop, then each successive entry will be an additional Target. But, you can change any item that is entered to be whatever you want it to be. The only limitation is that you can only have 8 OCO groups, hence a maximum of 8 targets and/or 8 stops. Refer to the following: Attached Orders: Add For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-23 21:14:33] |
While i can add target's and stops, there is a RED highlighted text, that says Target/Stops NoMatch.
[2024-04-23 21:19:45] |
Refer to the following: Attached Orders: Order Quantity Matching For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
