Date/Time: Sun, 19 May 2024 22:10:39 +0000
Chart View
View Count: 92
[2024-04-23 07:14:29] |
User124195 - Posts: 2 |
Dear SierraChart-Support, I hope you are doing good. In my SierraChart Windows I can not scroll to the left or right side, even so I have save the settings to load 500 days. The Lock File Space is not on and I have entered the Scroll bar. Unfortunately, this is not working either. I have attached a picture. I only have issues with the GC-Future Chart. I tried to duplicate another chart and then switch it to GC. But this is not working. Do you have an idea what is wrong with the Chart Settings? Best regards, Carolin Date Time Of Last Edit: 2024-04-23 14:33:03
[2024-04-23 15:16:35] |
John - SC Support - Posts: 31733 |
Make sure you actually have the amount of data loaded that you think is loaded. The most likely reason for not being able to scroll is that there is no additional data off the screen for you to scroll to see. Refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data There is no image attached, so we can not see what you are seeing. Please try to attach an image by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-24 10:40:35] |
Dear John, thank you for your reply. I found the solution this morning. Have a nice day. Carolin |
