Date/Time: Sat, 18 May 2024 16:54:14 +0000
How to install a floating cursor ?
View Count: 55
[2024-04-22 18:37:59] |
User107610 - Posts: 1 |
Hi How to install a floating cursor tool among the tools available on the chart, which can be used to mark a place, figure or e.g. a linear correction shape on the chart Starting from: Customize Control Bar 1 (I have my tools under it) Selected Control Bar Commands (table) What's next? .... And of course how to cancel it (all other pointers I cancel with Pp of the mouse) |
[2024-04-22 18:39:37] |
We are not understanding what you are asking for in terms of a "floating cursor tool". Please give us more information on what you are wanting to do. Also, refer to the following for how to setup Control Bar buttons that can select a tool and a specific tool configuration: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
