Date/Time: Sun, 24 Nov 2024 23:44:01 +0000
Error in operation non-sim
View Count: 190
[2024-04-22 18:33:04] |
User40969 - Posts: 1 |
2024-04-22 07:45:46.027 | Order update (Order reject). Info: Non-simulated Trade Account (xxxxx) cannot be used with Trade Simulation Mode. Internal Order ID: 102. Service Order ID: (none). Symbol: MGCM24_FUT_CME.
[2024-04-22 18:35:08] |
You are trying to send an order to your live account, but you have "Trade >> Trade Simulation Mode Enabled" enabled. Select "Trade >> Trade Simulation Mode" and make sure there is NOT a checkmark next to it, this will indicate you are in live trading mode. Refer to the following: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-22 19:03:42] |
Sierra_Chart Engineering - Posts: 17163 |
Make sure Trade Simulation Mode is disabled, both in the main instance of Sierra Chart and the sub instance. Both instances.
