Date/Time: Sun, 19 May 2024 23:32:41 +0000
placing a trailing stop order from the chart
View Count: 101
[2024-04-22 15:14:42] |
trade_for_profit - Posts: 2 |
Hello, Can I place a trailing stop order from the chart? by clicking on the specific price level? Not from the chart trading window, I know it is possible, but requires entering the price manually. I would like to place an order as soon as I see the setup, without typing the price in the box. Is it possible on sierra charts? |
[2024-04-24 02:13:38] |
Sierra_Chart Engineering - Posts: 14423 |
Yes you can add this order type to the Chart Trading shortcut menu: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-24 19:33:53] |
I did as described, it works. Thank you |
