Date/Time: Sat, 18 May 2024 16:54:17 +0000
[User Discussion] - Comparing separate days
View Count: 74
[2024-04-22 14:33:20] |
WiddyTrading - Posts: 5 |
Good afternoon. I am working on a study collection that would compare ETH vs RTH. I am running into an issue where ETH starts 1 day prior to the RTH session so my data to compare is always off by +/- 1 day. Do you have any advice for how to overcome this? I currently have 3 charts. Chart #1 calcs ETH data Chart #2 calcs RTH data Chart #3 would compare the two to get a specific value. Chart #3 is where I am running into the problem where the two numbers are always off by 1 day. Either 1 day forward or backward depending on how I build Chart #3. Am I thinking about this incorrectly? Thank you. |
[2024-04-22 15:52:31] |
We do not know what exactly you are doing, so we can't really give an exact answer. But, keep in mind that the ETH starts in the prior day, so having a result that is "off" by 1 day could be correct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-22 16:05:23] |
I am aware that it is correct. I am wondering how I can overcome that. Is there a better way of approaching this computation outside of what I am thinking? Not even necessarily looking for an exact answer. Moreso, just a general direction of how to potentially solve. |
[2024-04-22 16:21:14] |
We can not comment further without specific information on what you are doing. We have set this as a User Discussion, as there may be other users that have tried to do something similar and therefore understand at a higher level what you are trying to accomplish and can give you some insight. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
