Date/Time: Sat, 18 May 2024 18:25:37 +0000
[Programming Help] - ACSIL Move to Break-Even issue
View Count: 66
[2024-04-22 12:25:39] |
User92573 - Posts: 491 |
Dear Support I have a study that implements a move to breakeven at a specified offset. Same SYMBOL Same Chart so sc.BuyEntry / sc.SellEntry and I am closely following the example in "tradingsystem.cpp" line 1744 with the exception of sc.BuyEntry instead of sc.BuyOrder etc. {
//Move to breakeven on Stop Attached order // Create an s_SCNewOrder object. s_SCNewOrder NewOrder; NewOrder.OrderQuantity = 2; NewOrder.OrderType = SCT_ORDERTYPE_MARKET; NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED; //Define the Attached Orders to be attached to the main Market order //Target 1 NewOrder.Target1Offset = 10*sc.TickSize; NewOrder.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT; //Common Stop NewOrder.StopAllOffset = 10*sc.TickSize; NewOrder.AttachedOrderStopAllType = SCT_ORDERTYPE_STOP; // Set up a move to breakeven action for the common stop. // This is a common setting and applies to all Stop Attached Orders set on the main order. NewOrder.MoveToBreakEven.Type=MOVETO_BE_ACTION_TYPE_OFFSET_TRIGGERED; //After 5 ticks of profit, the stop order will be moved to breakeven NewOrder.MoveToBreakEven.TriggerOffsetInTicks= 5; NewOrder.MoveToBreakEven.BreakEvenLevelOffsetInTicks= 0; sc.BuyOrder(NewOrder); // replaced with the below } My version is as follows: {
// Create an new order object. (Note this is the Object, not the Order!) s_SCNewOrder NewOrder; NewOrder.OrderQuantity = i_Orders_Quantity_For_Trade; if(Direction == 1 && Entry_Price > Last_Trade_Price) { NewOrder.OrderType = SCT_ORDERTYPE_STOP; } else if(Direction == 1 && Entry_Price < Last_Trade_Price) { NewOrder.OrderType = SCT_ORDERTYPE_LIMIT; } else if(Direction == -1 && Entry_Price < Last_Trade_Price) { NewOrder.OrderType = SCT_ORDERTYPE_STOP; } else if(Direction == -1 && Entry_Price > Last_Trade_Price) { NewOrder.OrderType = SCT_ORDERTYPE_LIMIT; } //NewOrder.OrderType = SCT_ORDERTYPE_STOP; //SCT_ORDERTYPE_MARKET - SCT_ORDERTYPE_LIMIT NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED; NewOrder.Price1 = Entry_Price; //Define the Attached Orders NewOrder.Target1Offset = Target_Price_Offset; NewOrder.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT; //Common Stop NewOrder.StopAllOffset = Stoploss_Price_Offset; NewOrder.AttachedOrderStopAllType = SCT_ORDERTYPE_STOP; // This is a common setting and applies to all Attached Stop Orders that are attached to the main order. NewOrder.MoveToBreakEven.Type = MOVETO_BE_ACTION_TYPE_OFFSET_TRIGGERED; NewOrder.MoveToBreakEven.TriggerOffsetInTicks = BreakEven_Trigger_Offset); // Entry Order if(Direction == 1) { sc.BuyEntry(NewOrder); } else if(Direction == -1) { sc.SellEntry(NewOrder); } // Remember the order IDs for subsequent modification and cancellation Target1OrderID = NewOrder.Target1InternalOrderID; Stop1OrderID = NewOrder.Stop1InternalOrderID; InternalOrderID = NewOrder.InternalOrderID; // I added "r_InternalOrderID = NewOrder.InternalOrderID" as I'm not sure if using "InternalOrderID" with "NewOrder.InternalOrderID" // might cause a conflict. I'm not sure if it's reserved word? r_InternalOrderID = NewOrder.InternalOrderID; } The example does not suggest a test for working status is required however when I place a Buy_Limit order or a Sell_Limit order and it is not filled I still get an unexpected line when the Breakeven offset is triggered. This is shown in the attached image. It also seems to present the PnL from the Entry? The line can only be removed buy "Clearing all Sim Orders and Data." Any help or direction appreciated. |
Sierra ACSIL Move to BreakEven.png / V - Attached On 2024-04-22 12:25:14 UTC - Size: 81.1 KB - 18 views |
