Date/Time: Sat, 18 May 2024 19:03:00 +0000
Data - All Services / Swing Trading Historical Data Inquiry
View Count: 90
[2024-04-21 17:34:23] |
User871209 - Posts: 81 |
Hello, I'm currently connected to Data - All Services and using Forex - FXCM for FX trading. As a swing trader, I rely heavily on identifying support and resistance (S/R) zones, particularly those on the monthly timeframe. However, I've noticed that the maximum number of candles available is limited to 197, which restricts my ability to analyze historical data thoroughly. Could you please suggest an alternative service or solution that would allow me to access a more extensive historical dataset? Looking forward to your assistance. Regards, |
[2024-04-22 00:07:12] |
Sierra_Chart Engineering - Posts: 14423 |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Also are you referring to historical Intraday data or historical Daily data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-22 00:07:46
[2024-04-22 06:07:25] |
Good morning, Thanks for the link, I went one by one and I have the settings set at the highest levels in these, I am using only Historical data. Question, if you open let's say a USDJPY chart how many monthly bars are you able to see on your side? I can only see 198 candles. Please advise what else I might be able to do. Regards, |
[2024-04-22 15:36:04] |
For USDJPY there is data going back to December 2007. Follow the instructions in the link given in post #2 if you are not getting data back to that date.
