Date/Time: Sun, 19 May 2024 00:28:45 +0000
data missing in TAL after update
View Count: 88
[2024-04-19 00:03:51] |
User82032 - Posts: 35 |
Updated to v.2629 and found all data missing from the TAL. Saw earlier post which mentioned the new feature requiring one to select a Simulation State. I followed the instruction and still it did not solve the problem. Thanks |
[2024-04-19 01:39:59] |
Sierra_Chart Engineering - Posts: 14423 |
We need to know what you want to display, and we need to see a screenshot, of the settings you have in the Trading Activity Log Settings window.
[2024-04-19 02:11:22] |
We know what the problem is. You need to reselect the Symbol. And also set the Simulation State.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-19 04:06:26
