Date/Time: Sat, 18 May 2024 20:36:42 +0000
Trade acitivity log issue
View Count: 187
[2024-04-15 12:28:02] |
MarcOh - Posts: 162 |
GM, sorry to bother you again, but Im bit at a loss. The trade activity shows me points for two months and dollar amounts for the month of march, although I have set everything to currency. Am I making a mistake in my thinking? Thx (attached file for clearification) |
trade- statistic.png / V - Attached On 2024-04-15 12:25:36 UTC - Size: 2.23 MB - 28 views |
[2024-04-15 14:25:42] |
Sierra_Chart Engineering - Posts: 14423 |
Not sure about this. What happens when you select Edit >> Refresh Log. Do the values change? What happens when you select a specific symbol rather than All Symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-15 14:26:04
[2024-04-16 06:06:47] |
GM nope. value does not change. Tried it already. Even if I select points, the overview remains unchanged. But I don't want to annoy you with this. Maybe I can work it out on my own. It is only annoying because the *statistics are not correct with the two different data representations Date Time Of Last Edit: 2024-04-16 06:11:29
Screenshot_1.png / V - Attached On 2024-04-16 06:06:26 UTC - Size: 334.06 KB - 26 views |
[2024-04-16 15:17:39] |
bradh - Posts: 859 |
Maybe a dumb question, but did you click Apply?
[2024-04-16 17:24:00] |
I did yes. :) |
[2024-04-16 17:25:02] |
Trying to update to the current version now. Lets see if someth changes
[2024-04-16 18:38:08] |
nothing changed. Tried to set to currency and points and shows me both points. very odd. |
Screenshot_6.png / V - Attached On 2024-04-16 18:37:30 UTC - Size: 1.16 MB - 25 views |
[2024-04-17 01:44:25] |
We will be looking this over as soon as we can.
[2024-04-22 15:23:15] |
We are not able to reproduce this. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings And be sure to disable Use Custom Symbol Settings Values. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-22 15:23:34
