Date/Time: Sat, 18 May 2024 19:02:57 +0000
Replay Question
View Count: 101
[2024-04-14 19:58:56] |
User373245 - Posts: 42 |
Hi - I want to replay a strategy on forex pairs. How far back am I able to go and what is the process of loading that data? I'm on the Denali feed. Thank you. |
[2024-04-15 10:58:34] |
Calculus - Posts: 88 |
I believe you can go back as long as you want, if you have the data. So if you want to Replay for a year ago, all you have to do is make sure your Chart can do that, so under Chart Settings and then Data Limiting make sure you use 400 days under "Days to load for intraday chart data type". It's pretty simple. |
[2024-04-22 05:09:14] |
Sierra_Chart Engineering - Posts: 14423 |
See: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
