Date/Time: Wed, 16 Sep 2026 02:29:44 +0000
market replay problem
View Count: 749
[2024-04-11 18:03:55]
User251447 - Posts: 34
Hi
I am trying to do a market replay but some reason it's not moving forward when I click on forward arrow button but when I go back it seems to be working fine but not forward. I have checked that the market replay goes forward by skipping a few days and it does but some reason when I select market replay, input the date and time and click play or click skip it seems to be not working or skipping 1 second but I have set it as 1 hour to skip.
[2024-04-11 18:06:01]
John - SC Support - Posts: 47903
The first thing is to ensure that there is data in the chart going back to where you are trying to start the replay from. When you enter a Date and Time to start from, that date and time have to already exist in the chart, or the replay will not work. Refer to the following;
Replaying Charts: Replaying Chart from Specific Date-Time
Once you have the replay actually replaying correctly, then let us know if you still have an issue with the "forward" button. There is no reason for this not to work, except if there is not enough data in the chart to skip as far forward as you are wanting.
