Date/Time: Sat, 18 May 2024 10:08:06 +0000
Aligned Flex Renko bricks
View Count: 72
[2024-04-11 13:00:09] |
Theodore01 - Posts: 1 |
Hello, There's any way to align Flex Renko like normal renko is aligned? (kind of "Aligned Flex Renko Bar" option) I'm using aligned Mean Renko (flex with 50% offset) in another app and the trends look better (with less noise / reversals) than non-aligned ones. Of course I love Sierra's speed and configurability and I would love to see this option here. Thanks! |
[2024-04-11 15:20:33] |
There is not an option for aligning the Flex Renko, just the one option for "Aligned Renko". The only option to do something like this would be to create a custom study that creates the bars you want. Refer to the following: ACSIL Interface - Custom Chart Bars https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
