Date/Time: Sat, 18 May 2024 06:22:25 +0000
spreedsheet output repaint and misplaced at wrong bar
View Count: 69
[2024-04-10 16:14:45] |
User970210 - Posts: 83 |
Hi, I have used formula =IF(ID45.SG1@3=1,C3,R4) to create a new indicator. but I found out during backtest there is repaint output (normal behavior due to new data?) and misplace the plot to wrong bar. this constant repaint completely mess up the signal. I tried to use alert only based on bar close for ID45.SG1 without success. any advice will be appreciated. Song |
[2024-04-11 06:53:16] |
Sierra_Chart Engineering - Posts: 14423 |
What do you mean by this: there is repaint output
This is not possible: and misplace the plot to wrong bar.
Also refer to: Chart Studies: Study Calculation Precedence And Related Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-11 06:53:30
