Date/Time: Mon, 20 May 2024 01:15:56 +0000
Color Bar based on alert
View Count: 79
[2024-04-09 17:48:39] |
User360283 - Posts: 440 |
Please add an option to print a vertical line from the top to the bottom of scree with a user set width and color. This will make the alert much more visible Thanks |
[2024-04-09 20:24:35] |
John - SC Support - Posts: 31734 |
You can do this now by setting the Draw Style for the Color Bar to be "Background". You can set the color and width of the background coloring and it goes from top to bottom of the graphics area. Refer to the following: Chart Studies: Background (ACSIL: DRAWSTYLE_BACKGROUND) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
