Date/Time: Wed, 22 May 2024 02:41:10 +0000
DOM Recent Volumes for Alerts
View Count: 128
[2024-04-06 16:06:45] |
masedi - Posts: 37 |
I have a DOM with the timeout setting: Recent Bid Ask Volume Timeout in Milliseconds:3500 I need to access the recent ask/bid values exactly how they are displayed in the DOM windows (screenshot attached) to trigger some alerts. How can I access these values to reference in the alert formula? I tried to search for the exact answer for several hours with no luck. |
Screenshot 2024-04-06 200004.png / V - Attached On 2024-04-06 16:06:16 UTC - Size: 61.85 KB - 32 views |
[2024-04-08 14:52:23] |
John - SC Support - Posts: 31787 |
That information is not available through the built-in tools. You would need to create a custom study to get access to that data. Refer to the following: sc.GetRecentAskVolumeAtPrice() / sc.GetRecentBidVolumeAtPrice() List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-08 18:20:21] |
Thanks. Is there a way to display these recent bid/ask volumes in the DOM only if they are above a certain threshold? |
[2024-04-08 19:20:12] |
There is not an option for this.
