Date/Time: Tue, 21 May 2024 15:23:25 +0000
I have read all the support documentation and I still have question about an order type
View Count: 154
[2024-04-05 18:27:52] |
User212833 - Posts: 13 |
Hello, Ive read all the documentation but I still can not tell is this certain type of order is supported. I would like a price target closing order that can chase the market price if blown through. For instance, if I buy at 100 and set a sell limit order at 105 and the market blows through to 110...is there a way I can have that sell order chase the market price until it turns around and starts to tick back to a designated offset....like 3 points or something? (So, in my example, if the market goes strait to 110, and I have an offset of 3....then when it turns around the closing order I placed at 105 would trail up to 110, then when it ticks down to 107 it would close) I researched limit chase orders, triggered trailing stops, etc and I can seem to get them to work. |
[2024-04-08 19:22:59] |
Sierra_Chart Engineering - Posts: 14440 |
You can create this as a custom ASCIL study to control an order. See this study as an example: Attached Orders: Study Controlled Targets and Stops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
