Date/Time: Mon, 20 May 2024 16:36:37 +0000
Color Bar Based on Alert Condition on Heinkein Ashi chart
View Count: 99
[2024-04-05 15:54:13] |
User600819 - Posts: 43 |
I'm running Heinkein Ashi using HL Bars. I only have the "High" and "Low" visible per my attachment. I'm running into issues trying to color the bars when they are "Blue". I can't figure out what inputs are determining it. Thanks |
HA Color Bar Issue.PNG / V - Attached On 2024-04-05 15:52:00 UTC - Size: 206.99 KB - 28 views |
[2024-04-05 16:56:57] |
John - SC Support - Posts: 31744 |
The "Up" bars are blue because that is the color you have set for the "High" of the bar. The other ("down") bars are white since you have the "Low" set to White. We are not sure what affect the "Color Bar Based on Alert Condition" is having as we do not have any information on this study and how it is setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
