Date/Time: Mon, 25 Nov 2024 02:27:17 +0000
Can Dom Graph Exclude Outliers?
View Count: 282
[2024-04-04 15:22:28] |
Le Dharma - Posts: 73 |
Hey Sierra. Right now my Dom Graph follows the single highest Volume Bar (row). And if that Bar is an outlier, compared to the rest of the Dom Graph, It will skew the entire Graph to be too small, or to cycle between small and big. Can we exclude outliers on the Dom Graph? Or maybe the Dom graph Size could follow an Average Line? Do yall have options to control Dom Graph Controllers, or ways to mitigate the Outliers? Also, Does DOM graph come as a Study, instead of a chart window attachment? Thanks Sierra. My best to yall. -Ben |
[2024-04-04 16:20:31] |
There is not a way to control or filter the DOM Graph to show only certain values or exclude certain values. We are also a bit confused by your statement about skewing the graph, as the DOM Graph does not have any impact on the size of the scaling for a chart. So your chart should not be adjusting due to the DOM Graph. The one option that we want to point out to you is the "Market Depth Historical Graph" (you need to be on one of the Advanced packages to use this). This will allow you to define a range of data based on the percentages of the Maximum Depth. So you could exclude outliers by only showing data in the 90-95% range for instance. The only downside to this study is that there is not a way to only show the most recent information. It will always show the historical information as well for each bar. Refer to the following: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
