Date/Time: Tue, 04 Nov 2025 13:55:26 +0000
Incorrect Session Volume Profile for stocks
View Count: 402
|   [2024-04-03 19:44:25]     |
| User987537 - Posts: 2 |
                Hello Support, I have set up a 30-minute volume profile chart for stock but the volume profile for the first 30 minutes is incorrect. Most of the time, the first 30-minute volume profile only displays "Low Volume" when it should have the most volume or has the POC stuck at a particular price point. I suspect there is either some setting issues with my chart or there is a data issue. Please see the attached images for your information. The volume profile for QQQ should resemble the profile of NQ Date Time Of Last Edit: 2024-04-03 19:46:12
|   [2024-04-03 20:49:38]     |
| Sierra_Chart Engineering - Posts: 21299 |
                First make sure that the time zone of the chart is set correctly and the Session Times. For example if you are using US Eastern time, the Session Start Time  for the chart needs to  be 9:30:00. Refer to: Time Zone Setting And you also need to use the US consolidated tape symbols: US Stock/Equities Consolidated Tape Data Feed For example: MSFT If you need real-time data then you need to pay the real-time exchange fee. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-03 20:50:59
|   [2024-04-04 09:07:30]     |
                HI I have already subscribed to Nasdaq TotalView. Is it necessary to subscribe to US Equities Consolidated Tape Data Feed?
|   [2024-04-04 13:36:49]     |
                Yes if you want full and accurate volume in real time.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
