Date/Time: Mon, 20 May 2024 15:42:26 +0000
SC opens up, start calculating charts, and closes down on its own
View Count: 109
[2024-04-03 07:43:26] |
User210127 - Posts: 23 |
Hi Support, as per the tile, I open SC this morning, it opens the application, charts reload and start calculating, and it sueendly stops and crashes down/closes down. I am on 2610. Thank for the help Dom |
[2024-04-03 16:47:13] |
John - SC Support - Posts: 31743 |
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart. If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
