Date/Time: Mon, 20 May 2024 14:53:48 +0000
TPO merge doesnt stay intact, after switching symbols and SC restarts
View Count: 114
[2024-04-03 01:11:57] |
User763335 - Posts: 49 |
Hello after merging profiles, it doesnt stay intact, after switching symbols and back. ie) 1) Ticker A. Merge with next profile. TPOs merged 2) Switch to a different ticker B. 3) Switch back to original ticker A. 4) TPOs unmerged How do we ensure the merge stays intact across symbol switches on the same chart and also gets saved as part of chartbook(across SC restarts), so I dont have to keep doing the same merge multiple times? Thanks |
[2024-04-03 01:46:27] |
Sierra_Chart Engineering - Posts: 14433 |
Yes this is true. There is no way around this. You cannot change the symbol and keep the merges and splits.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-03 01:46:49
[2024-04-03 12:15:34] |
Ok, can this capability be implemented in the future..? For now, I'm just marking the merge with chart drawing for reference. Thanks |
[2024-04-03 13:29:30] |
No this is not something we would add.
