Date/Time: Mon, 20 May 2024 17:23:18 +0000
Time
View Count: 154
[2024-04-02 14:44:03] |
User699497 - Posts: 5 |
Good morning, With the time changes in the USA and now in Europe, I have different times. As in the attached photo, it is 15:36 and the graph should also be, but no, it shows 14:36, despite the data being correct and in real time. Can you help me resolve this? Thanks. Paulo Andrade |
[2024-04-02 23:03:08] |
Sierra_Chart Engineering - Posts: 14434 |
We cannot help with this. There is no issue. You have the correct time within Sierra Chart according to the time zone of the chart and that is what counts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-02 23:03:33
[2024-04-05 16:26:05] |
I think I solved the problem. I went to -Global Setting-Time Zone Setting and changed -Time Zone (List) to -London (+0 GMT/+1 BST). It was set to UTC (+0 UTC). |
