Date/Time: Sun, 05 May 2024 19:07:27 +0000
Delayed options data
View Count: 121
[2024-04-02 13:04:22] |
User502866 - Posts: 6 |
I'm currently unable to obtain any options data, I have tried several symbols e.g ESM24-CME and ZNM24-CBOT and have checked the following. 1.Update current version 2.Global settings-data/trade service settings-allow support for Sierra chart data feeds-YES 3.Global settings-symbol settings-update from server. 4.Started fresh with a new chartbook It was working last week, however, when I go to find symbol 'get options' now, nothing happens. In the message log it states 'Received symbols for underlying request from server: Underlying: ZN. Count 0'. This is the same for the ES |
[2024-04-02 13:42:02] |
Sierra_Chart Engineering - Posts: 14236 |
We had to disable delayed options data. There is a performance issue related to this .
[2024-04-02 14:16:09] |
Ok, thanks for the quick reply. Moving forward, is this temporary? |
[2024-04-02 14:27:12] |
Yes we can do delayed CME Group options data but on a separate port.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-02 14:27:22
[2024-04-02 14:36:11] |
Ok thanks, just one final question. When this has been done will the information be on a support board thread, I don't want to waste any more of your time asking about delayed data issues when there may be more important issue related to live data/accounts. Thanks for your help |
[2024-04-22 04:04:23] |
This is resolved but a new version is required and we need to release that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-22 04:05:26
