Date/Time: Fri, 10 May 2024 02:52:03 +0000
Name Label (Reverse Colors) option can't be turned on with Study Overlay
View Count: 94
[2024-04-02 04:52:02] |
User832812 - Posts: 7 |
Hi SC, first of all thank you for your amazing software. I really like it. I have two charts, on my left chart there is a Horizontal Line at Time study (US Open price at 09:30) and on the right chart i have the study overlay which refers to the Horizontal Line at time study. In the study settings of the left chart, Name Label and Reverse Colors is enabled for the SG1 Line. On the right chart study overlay settings, Name Label is turned on for SG1 but i can't turn on reverse Colors. Upon applying settings it is unchecked again. I have other Study Overlays on the right chart (volume profile levels, daily range bands) which are set up the same way where reverse colors work. Thanks for your support. |
[2024-04-03 15:28:07] |
John - SC Support - Posts: 31509 |
In general, when you use the "Study/Price Overlay" the Subgraph Settings can not be changed in the Study/Price Overlay. You need to change the Inputs in the Study/Price Overlay to allow the settings to be changed. But, it sounds like you are having a different problem, where the setup of the source study is not flowing into the Study/Price Overlay and then you can not change it. Still, the first thing to do is to change the Input on the Study/Price Overlay for "Use Subgraph Name/Value Related Display Settings from Source Study" to "No" and select "Apply", then try changing the Name/Value Label as you want it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-03 16:15:59] |
Yes, with this setting I am able to change the label. even though that setting was already there on the source study - somehow it did not came trough to the study overlay. I think that has to do something with the Horizontal Line at Time study, where specific subgraphs settings are not transferred over to the Study/Price Overlay. With the Volume by Price study for example, study/price overlay works great |
