Date/Time: Mon, 13 May 2024 15:24:46 +0000
Replacing SMART with other routes does not send order
View Count: 100
[2024-03-22 20:28:38] |
funbun - Posts: 76 |
the format for IB according to the documentation is AAPL-STK-SMART-USD where SMART is the route. I tried to replace SMART with other routes but the order doesn't go through. Is it the only route that SC mapped? |
[2024-03-22 21:48:38] |
Sierra_Chart Engineering - Posts: 14337 |
Sierra Chart takes the symbol that you specify and fills out different members of the TWS contract structure. You have full control over what you are sending Interactive Brokers. It is all explained here: Interactive Brokers Symbols: Accessing Contract Description in TWS for Symbol Details There is no "mapping" that occurs. What you specify is sent straight through to TWS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-22 21:48:45
