Date/Time: Sat, 11 May 2024 17:42:19 +0000
Different price points on DPM vs Chart
View Count: 118
[2024-03-22 17:01:54] |
L2Ltrades - Posts: 45 |
Please see the picture attached. My price point on the DOM is different than that on the chart. This is causing issues closing a position at the desired price point. The account selected on the DOM and the chart window are the same.
Capture 1.PNG / V - Attached On 2024-03-22 17:01:42 UTC - Size: 142.59 KB - 24 views Attachment Deleted. |
[2024-03-22 17:29:54] |
Sierra_Chart Engineering - Posts: 14315 |
Make sure the Open Position Average Price is set the same between those two charts: Trading Information Windows: How Average Price for Positions Is Calculated and Used Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-22 17:36:17] |
Will try that. Thank you.
